Hi all! I apologize in advance for my complete n00b-ishness. I recently purchased an SLS QS1000 system:
http://www.slsloudspeakers.com/content/view/40/53/
To go with my Sony Grand Wega KDS-60A2020 HDTV:
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&langId=-1&productId=20004511
Being that the TV has a much nicer input selection than the receiver, I bought an optical cable to connect them. So I got this all set up tonight, and the short version is that I get no sound from the speakers, specifically when trying to use my 360 connected to my TV's component input. The optical indicator on my receiver is blinking, which according to the manual means that there is no input signal. Well crap. I checked the connection, and the optical cable is plugged in properly on both the TV and the receiver, and I can't find any option on my TV that says "Turn optical output on". Everything seems to imply that it should happen automagically.
So what am I doing wrong? I really want this to work, so any help would be greatly appreciated. Thanks!
