1 - 5 of 5 Posts
· Registered
Hey everyone.. I've been into HTPCing for a while by am fairly new at the form..
This is was I have
Samsung 50" Plasma
Gigabyte GA-P31-S3L
Using On Board Audio via coaxial
Windows 7 Media Center
SLS Q-Line Gold Receiver and 6.1 setup
Problem I'm having is when it comes to 5.1 stuff. I'm getting separation between the front L, center, and front R but it sounds like the rear L and rear R are mix together. Whatever comes out of one comes out of the other. Even when I do the speaker tone test in media center.
When I do a tone test on the receiver itself, they are all separate. So, originally, I thought it might be a sound card issue. But, here is the weird part. If I go into the control panel and select the optical output and set Dolby output for it and click the test tone button, there is speaker separation.
So, it seems like the only time the rears are mixed are within Media Center
Any ideas?
Thanks in advance
· Registered
In MC speaker test which connection did you choose?
There are several options and you have to select Digital/Co-axial and not analog.
I believe it doesn't matter what you select since the global default audio device is SPDIF (co-axial). Whatever you choose, MC is going to passthrough the signal over the co-axial connection. Your sound is most likely going through properly.
Have you played anything and checked your AVR display?
If it shows DD/DTS then it is sending the correct signal.
· Registered
Discussion Starter · #4 ·
For the media center setup, I'm using "Single RCA (Digital) - 5.1 Surround"
I'm using the movie "Seven" and set the DVD Audio selection to "Dolby EX Surround Sound"
The AV Receiver is showing the Dolby symbol with a "PL" next to it which I'm assuming is "Pro Logic"
· Registered
Use a Dolby Digital "channel-check" file sample. That will tell you FOR SURE, without all the guesswork.
1 - 5 of 5 Posts
