I am new to projectors so bear with me.
I have spent the last few days digging into around the message board and still am unable to answer my questions...
First off, on the 1030Q, what REALLY is the cutoff on the serial for 32kHz hor. scan, I have seen above 50xx, above 50xxx, and above 50xxxx.
My projector S/N is 10xxx which is above 50xx but under 50xxx obviously. If I am stuck with 26kHz I will be bummed!
I know what to do if I am able to do 32kHz, that's easy. But what are my options if I am stuck in 26kHz land. I don't know enough about PowerStrip to tweak it correctly yet. Will I be able to do [email protected]? I know I won't be able to do [email protected] unless I have a 32kHz 1030Q.
Finally, I am building a VGA to RGB2 cable. I have the pinouts, but I want to know about the composite sync. I have read that you can put the h-sync and v-sync together in the composite sync and then run neg. sync out of PowerStrip. I have also read that you have to build a circuit to make composite, which one is true??
So to sum up
s/n above 50xx, 50xxx, or 50xxxx - (mine is 10xxx)
What can I do if I am stuck with 26kHz to get 480p or close to it
Composite sync - twist together or build a circuit.
So to sum up
