Status
Not open for further replies.
1 - 3 of 3 Posts
Is there any sound card out there that would enable me to use my HTPC as a audio receiver/amp? Obviously it needs to have output connections to the speakers...
Is it a good idea to do it this way?
Discussion Starter · #2 ·
well none of those are powered so you wouldn't be able to use them as an "amp" per say, nor can you really use them as a reciever since i don't think you can switch inputs on the fly with a remote control.
If you buy powered speakers and hook them up to one of those cards you might have a solution. Depending on your home theater needs you can buy anything from a set of logitech Z-680 5.1 speakers, which have a built in reciever/proccesor that can decode dolby digital and dts and switch between analog and two digitinal inputs with a remote control..
or you can go as high end as 5 M&K S-150P and hook them straight up to the sound card, i have the non powered version and they are great.
http://www.mksound.com/s150Pthx.htm
1 - 3 of 3 Posts
Status
