Status
Not open for further replies.
1 - 2 of 2 Posts
I have a mits dvhs vcr that was connected to my mits rptv via firewire. However, now I just ordered a crt projector and I need a way to decode the mpeg stream. I was considering either a old panasonic stb or the samsung stb. But, then I thought I could just use my htpc to do it? Is that possible, play the movie with the vcr decode with the pc and then output to the crt from the pc?
If you have XP, look/search for dvhstool.
1 - 2 of 2 Posts
Status
