1 - 3 of 3 Posts
Hi,
I recently purchased a HTPC and am trying to connect to my older rear projection CRT TV. TV only has component in and I am trying to connect via HDMI out on HTPC. I am using a HDFURY 2 HDMI to component converter to connect. Only a blue screen comes up when connected. I have connected HTPC to a projector using HDMI and it works fine. Can anyone help me to be able to get this up and running? Trying to avoid buying new LED TV for as long as posssible. Thanks
my guess is that the TV does not support the resolution the HTPC/HD Fury is putting out...
try lowering the resolution maybe? (note, not sure how to do that when you cant see the screen to start with?)
1 - 3 of 3 Posts
