Hi -
I'm new to htpc's...I've read the FAQ & studied up on some interesting threads but I still have a couple (probably simple/dumb) questions.
I first started looking into htpc's after finding that no one out of the box consumer product existed. If I build a htpc I would mainly use it for:
1. Audio server - 85%
2. Photo server - 15%
In that order and at that percentage. This leads me to my first question.
1. Can a htpc - audio server be setup to play music (mostly mp3's) in multiple rooms? Can the music be independent at each location? How expensive & easy is this to do? Is it commonly done?
2. What is the slickest front end or UI for a htpc? I don't want the UI to actually LOOK like I'm running a pc. I want it to look polished and simple (for the wife).
3. Assuming the answer to #1 is "yes" then can I setup multiple LCD's in each of my rooms so users can control the audio via these LCD's?
4. This is probably the dumbest question but are htpc's always paired with a reciever? Is a reciever (I like the Harmon Kardon line) required and neccessary for a htpc to work properly. Any recommendations?
5. Once a htpc is setup what channel to I turn to to control it? Does this require a video modulator?
