These are questions about the June/July 2011 HTPC guide, written by Renethx: In your guide, you mention that the mini-ITX form factor is more expensive than the micro, due to the costlier small hardware. However, the 'standard' mini system is $333, while the mid-range micro system is $710. Even the low end micro ITX is more expensive ($452) than the mini ITX system. I'm not questioning your pricing, I'm just trying to understand, would I be getting a more powerful system? E.g., is the low end micro more powerful than the standard mini system?
Another question: In the standard 2D mini-ITX system, you recommend using the on-board Intel HD video drivers. I'm curious what noticeable limitations there are. In your summary table (Figure 17) you show partial support for 29.976Hz refresh rate for movies. What does this mean in terms of user experience, watching a 1080p movie for example?
Thanks much for your guide, it's a real time-saver!
-Randy
-Randy
