This is my setup:
HTPC - Gigabyte EG45M UD2H motherboard with HDMI, optical SPDIF, DVI-D and VGA
AV Receiver - Onkyo TX SR 605
Projector - Infocus IN72
When I set up my Home theater three years back, I choose to connect my projector to the AV receiver using component cables primarily for two reasons - 1) HDMI cables were new at that time and extremely expensive esp. because the running length between the ceiling mounted projector and the AV receiver is about 30 feet and 2) the projector itself is only 480p and at that time, I thought why HDMI when component would suffice.
Now I regret that decision.
When I tried to connect my new HTPC to the AV receiver through HDMI yesterday, there was no display. Upon reading the fineprint of Onkyo's manual, I found that a HDMI input cannot be down converted into component output and therefore, HDMI input can only be passed out through another HDMI out! So, my entire HTPC failed as my Onkyo is connected to the projector through component cables.
I bought some locally available VGA > component cables, HDMI > component cables to try connecting the HTPC to Onkyo, none of which worked. So basically I have no clue how to make my HTPC work unless I spend a fortune on rewiring and HDMI cables!!!
Can anyone help me out?
