Status
Not open for further replies.
1 - 5 of 5 Posts
Sorry for the newbie question but it's difficult to pinpoint some easy detail questions simply using the search function.
Anyway, how does the audio card from the PC normally connect to a typical home theater receiver? I notice that with Soundblaster 2, for example, that there doesn't appear to be an optical out or the normal RCA cables.
How does that work?
Discussion Starter · #3 ·
Originally posted by mrjmross
depends on the soundcard.....but I use the optical out from my Chaintech AV-710.
The other easy way is to use digital coaxial.
That Chaintech isn't too expensive. Surprising.
What soundcards have the digital coaxial output?
1 - 5 of 5 Posts
Status
