First, hello and thanks for looking at this...
I'm new to the HTPC and gaming thing. I am building a semi-cheap PC to use for gaming in my theatre room. My audio setup is standard 5.1 with a decent Denon amplifier.
The motherboard I am using in the PC has onboard Intel HD Audio. My questions:
1. What is the best way to get surround sound from games?
I have a multi-channel input on the back of the denon receiver/amplifier. This is the same input for SACD or DVD-Audio. From reading a few posts, it seems as if this is the best way?
Check out this link (and scroll down to configuring 6 channel audio)
http://www.intel.com/support/motherb.../CS-020642.htm
This seems a bit bizzare to me, using the line in, line out, and mic in as analog outputs to the multichannel input of the amplifier/receiver.
Am I on the right track here? Or am I way off?
I'm on the right track, then I take it I will need 3 - "Y" cables (1/8" to RCA Stereo) in order to complete this setup?
Also, I do not have a digital audio connection on this motherboard (which is fine, I'll use my dvd player with coax digital connection for movies).
Comments will be appreciated, and thanks!
-Bob
-Bob
