Hi Everyone,
My HTPC is a bit underpowered (radeon 5450 with a dell optiplex gx620 - Pentium D at 3.2 GHZ). However, using MPC-HC the blurays play smooth as silk.
The problem is that I can't get the surround sound to work. I'm outputting the surround sound directly through the hdmi. Further, when I get a test file to test the surround sound, MPC-HC plays it perfectly. Even more so, when I play the same bluray through something like total media theater, I also get surround sound. Thus, it's some setting in MPC-HC that I can't figure out. The other players I tried (MediaTheater and PowerDVD) are bloated and cause the video to skip every onece in a while.
Can anyone suggest either a solution to the surround sound or suggest a much lighter player? Thanks!
