Hello, fellow nerds. I've just completed my first ever HTPC build. I've built plenty of desktops in the past but this is my first HTPC and also my first build of any kind in 4 years. What I hope to achieve with this machine is to replace my WD Player and have a few extra bells and whistles. I intend to use XBMC to organize and play all of my movies, tv shows and music which I have stored on external HDDs. I also intend to play emulated games (up to PS2, possibly Wii quality) with Hyperspin. Last, I'd like to be able to launch Steam out of XBMC. I've loaded all the software and everything seems to run properly. However, it is not quite optimal for showtime yet. Here is what I need advice on:
1. VIDEO: Research convinced me that the APU on my processor would suffice for an HTPC with light gaming capabilities. Yet video quality is not as good as my tiny WD player when playing 1080p movies. Resolution seems to look fantastic on stills, but as soon as there's a little action, it seems to look a little blurred and unnatural with movement. Also, navigating menus seems to get unbearably laggy in XBMC and doesn't seem to refresh very fast at all when loading artwork. My instinct tells me it's all due to the APU not being powerful enough. I'm inclined to buy a dedicated card but it has to be low profile and hopefully be more than powerful enough to handle all the things I mentioned that I'd like to do without any lag. Any suggestions on a card? It has to fit a low profile case so I'm not sure how powerful those things can be these days. Am I even on the right track with buying a vid card or is there something else I'm missing? Please help!
2. INPUT: I was leaning toward Flirc and my existing universal remote (which currently controls my PS3 and TV). However, I would need it plug it into a back port since I need the 2 front ports for controllers. Hence, no line of sight for the IR receiver. Anyone know of any decent remotes for HTPC that work will with Windows 8.1 and XBMC? I browsed Amazon and couldn't find anything except for the Logitech harmony remotes but I'm not looking to spend that kind of money.
3: Right now my sound and video are going to 2 separate places. HDMI directly to the TV and optical from the sound card to the AVR. The reason for this is because the difference in picture quality is night and day between routing HDMI through the receiver and going direct to the TV. Sound is no issue either way. However, going directly to the TV poses a problem because I lose 3D capability. Anything stereoscopic 3D must go through the receiver because I have several 3D capable devices (PS3, WD, etc.) and the 3D adapter only has on HDMI input. Again, I think the intolerable loss in video quality may be due to lack of GPU power. Any advice there?
Thanks to all in advance who may be kind enough to help me in my quest to create this dream machine successfully. It's been a passion project I've been wanting to take on for years so I'm really hoping to perfect it.
Here are my theater specs:
HTPC HARDWARE:
-Silvertone ML03B HTPC case
-MSI FM2-A75MA-E35 motherboard
-AMD A10-6800K 4.1GHZ Quad Core Processor (Radeon 8670D APU)
-8GB (4x2) G.Skill Sniper DDR3 2133 RAM
-ASUS Xonar DG 5.1 card
-Kingston 120GB SSD (OS, Frontends, Emulators)
-WD Blue 1TB HDD 6GBS (Roms, Media)
-Antec Gold 450W PSU
SOFTWARE:
-Windows 8.1 OEM
-XBMC Frodo (front end)
-Hyperspin (emulation)
-Steam (modern gaming)
DISPLAY & SOUND:
-65" Mitsubishi 3D Ready DLP (2010)
-Mitsubishi 3DA Adapter (converts SBS/OU to checkerboard)
-Yamaha AVR (2010)
-Klipsch RF series 5.1 speaker set-up
HTPC HARDWARE:
SOFTWARE:
-Windows 8.1 OEM
DISPLAY & SOUND:
-Yamaha AVR (2010)
