Hi I’m thinking about setting up a Windows Home Server 2011 to backup the PC’s in my house. I’m also plan on building an HTPC or two to replace my Verizon FIOS DVR. I know WHS is going away, but that will take years. Anyway I have a few questions as I have never built these types of machines.
I have a 55” LED and serving the highest quality HD content to it via a Micro HTPC is my primary concern. Eventually I may build or buy some extenders to stream to as well.
1) I would also like to able to record 3 or more shows at once. Are either the HDHomerun Prime.or the Ceton quad tuner good solutions for this with my Verizon cablecard?
2) Do all of the recommended builds satisfy my HD and recoding needs: Intel Sandy Bridge i3, AMD Llano and Intel i3 Clarkdale? Do you recommend one over the other considering my needs?
3) With WHS 2011, can this only backup Win7 and future Win8 PC’s or XP to?
4) With WHS 2011 can I, using standard methods, nightly back up a PC with drives larger than 2TB, or with more than 2TB over several drives?
5) With WHS 2011 can I build an HTPC with only a 64GB SSD (no other HDs) and record directly to the WHS only as well as store other content and media I want there to serve to my HTPC’s? Or if doable is this solution not recommended?
6) Can a windows XP pc be an extender, or just win 7 or later?
7) Should I wait for Win 8 or go with Win 7 now and upgrade later?
8) Does the version of Win 7 matter much; home, ulimate etc?
9) Can you stream ripped Blu-rays via WMC such that subtitles can be played?
