Hello one an all,
Be gentle... please, I am new an I have been combing the internet ALL day trying to find an answer to this dilemma I am having. I have looked in all the nooks and crannies I could find here but there doesn't seem to be an answer for me ... just yet. Hopefully y'all can help....
I have ReplayTV 4040. Direct TV. Hughes HIRD E1 satelite Box that has NO serial connection so I must use IR Blaster. The channels will not change correctly using any of the codes from setup or going into Custom/Replay Zone to change settings: (Inter-action delay; Response Delay; Pre-command delay; Inter-Command delay.) help.... please.
The symptom is when I key-in a channel or scroll the menu and select a program it doesn't add all the digits to the Direct TV box so it doesn't change to the correct channel. 206 comes in 20 or 26 or 06... Because of this I can't set it to record anything.... it won't go to the correct channel! So... I haven't gotten to any of the fun stuff I can play with on this new toy yet.
Can any of you help me?
Thank you so very much.
Kim
Kim
