Status
Not open for further replies.
1 - 2 of 2 Posts
Is it just my unit, or has anybody else noticed that some channels (maybe 10% of the channels) within the channel guide is not not displaying any information about what should be on? Is that normal for the less common channels - like QVC, etc. I also noticed that some channels that display what's on is not really what's on when you select it. I called DirecTV and they were of no help.
I have occasional problems with my Mitsubishi (Hughes) getting out of sync with the guide. I reset the box (unplug for a minute or two) and force it to reaquire the guide. The seems to fix it for another couple of months.
Also, make sure it knows your Zip code and the name of your local cable company if you have cable connected.
Tony
1 - 2 of 2 Posts
Status
