1 - 3 of 3 Posts
This isnt a typical ground loop issue that I know about so figured I would ask the experts on here what they thought.
I get a buzzing sound from the sub when plugged into the wall even when I dont have any other cable attached to it. When I check the front of the sub the cone is vibrating....
When I adjust the volume knob the hum/buzz gets louder. Ive moved it around the house and still have a buzz where ever I plug it in. Its a two prong plug in so I cant really use a cheater plug. Im pretty sure I dont have bad power as I dont get any humming from my speakers or anything else.
You guys think the sub is bad and need to send it back to Polk?
your wiring is not grounded properly.
1 - 3 of 3 Posts
