I have a rooftop antenna with a rotor. Most of the local stations here are strong enough that pointing the antenna accurately is not critical, but there are a couple stations that are weak enough that antenna aim is critical. With most of my ATSC tuners pretty much the only way to find the station is to rotate the antenna until the tuner locks in a picture. My Sony Bravia TV, on the other hand, has signal diagnostics that include something called IF-AFC %. This indicator reads 100 when no signal is present, but then as the antenna moves closer to the right direction the IF-AFC slowly drops until it gets down into the 60's when the SNR (signal to noise ratio) starts to flicker with an indication that something is there. Then when the SNR gets up to about 16 the tuner can lock in a signal. With my strong stations the IF-AFC gets down into the 30's. So it seems that unlike other signal indicators, for this one, the lower the number, the better.
The cool thing is that this IF-AFC indicator, whatever it is, indicates the presence of a weak signal long before any of the other signal diagnostics (SNR, the little color coded signal strength bars, and signal level) indicate that anything is present. Anyone know what IF-AFC stands for and what this is measuring? The manual for the TV just says "Select to view diagnosics information for the current signal," with no explanations as to what the different diagnostics are.
