Status
Not open for further replies.
1 - 5 of 5 Posts
I just put up a whisperflow box and am experimenting with the fans speeds. What temperature is too high and what temp is acceptable? Anyone know?
Paul
Your manual for your PJ will list operating temps. That should be your guide.
I would recommend as close to room temp as possible, somewhat higher if fan too loud.
But overall if you can maintain 75 degrees throughout a movie, you're n good shape. I cool mine to 78 degrees.
I own a DILA.
1 - 5 of 5 Posts
Status
