Status
Not open for further replies.
1 - 4 of 4 Posts
Anyone know approximate $ to install a complete HVAC system? I am planning a HT in upstairs of a detached garage that currently does not have heat/AC so I will need to have new duct work etc plus the heat pump. Approximate area is
I don't know costs in your area, but I live in the Atlanta area and was quoted $2700 for a basement (~1500 sqft) HVAC system.
As to which you would do first. I would do HVAC before electrical because the ductwork is larger and therefore more difficult to route so give it the first routing option.
$6K in Detroit area.
This included 6 vents, 6 returns, furnace and A/C. All flexiduct and specialtity non-vibrating grills, thermostat, associated electrical and installation and seperate thermostat and fan system in equipment room.
The vents and returns were distributed from wrapped aluminum rectangular duct work hidden in the soffits.
It is almost silent when operating.
The theater was a subzone of the family room / master suite.
1 - 4 of 4 Posts
Status
