Status
Not open for further replies.
1 - 6 of 6 Posts
Hi,
My replacement HVPS is now shutting off and the DS1 KV Low light on the Control pwb is lighting up every time the hvps goes down. What does that light indicate? Any possible solutions other than replace the HVPS?
God bless...
Mark
Umm, what PJ is it?
I have had several HVPS's die without that light ever coming on. I might be able to fix it and I know that Mike PArker repairs them too.
That would be cheaper than sourcing a good used one at this point.
Discussion Starter · #6 ·
HI,
Thanks for the help so far. Just an update I realized that the VIM might have something to do with this problem in that it has to power up so the hv protection circuit doesnt kick on. Sure enough, changed the VIM and the problem has stopped. Put the old VIM back in and the same problem shows up again.
1 - 6 of 6 Posts
Status
