I do not frequent other tech forums so I thought you guys could help me here.
I want to run a golf launch monitor which tracks a golf balls path and takes video of the swing.
Here is the spec they call out.
http://www.accusport.com/files/documents/vseries_v2.4.7/VSeries_2.4.7_SystemRequirements.pdf
I currently am running an old PC with the monitor. For every shot it renders video then it graphs the shot trajectory. This takes some time. I will likely end up with a 33" HDTV for viewing off the PC.
I have an old server it is a 2 duo cpu [email protected] Ghz
It has 4 gig of ram
Running 2008 Server R2.
The video card is weak as you would expect in a server. The power supply is 350 watts. I know I have to upgrade the power supply to get something decent.
Two questions:
Can I just run the server operating system, it says XP 64 bit is not supported.
What graphics card would you suggest?
Bill
It has 4 gig of ram
Two questions:
Bill
