After about 5 hours of searching, switching settings, and headaches... I am soo close to having VMC working the way I want.
Here is my setup:
HP running Vista 32bit, bluray .ISO backups, WMC, MyMovies, slysoft ANYDVD and virutal drive - feeding my NAD T175.
Here is what I have working:
I can get 7.1 sound from my computer to the T175 using the 3.5mm -> RCA desicrete input. I also figured out how to make the projector the primary clone monitor so that HD content will show on the project, rather than the monitor (will only do one due to HDCP)
Here is where I need help. If I have WMC full screen, go to MyMovies and select the BluRay I want to watch... WMC spins for a while and then nothing happens. If I run to my PC and take WMC out of full screen, AnyDVD will then scan the disk and the process moves forward.
If I have WMC not full screen and perform the same functions, it all works great and the movie starts quickly.
So for some reason the autoplay function isn't working in full screen mode.
Anything I am missing in MyMovies, etc?
Any other option of using different software to make this work properly?
Thanks for any help! I am really excited about how close I am!!!
Here is my setup:
