1 - 3 of 3 Posts
I see all sorts of deals on all sorts of shopping sites for low priced HDMI cables.
I see comments that the stuff they will try to sell you at the big box stores is over priced, but are these six for $10 not worth it?
I only need two right now: one for the home theater and probably one for the dish receiver.
Any comments?
Mike
Well, it depends. Usually economical HDMI cables are a good deal, though we have run into some assemblers who did not do a good job and had a high rate of failures. At short distances, any reasonably well-made HDMI cable is going to do everything you ask of it. As distances get longer, cable quality becomes more relevant. Certainly the prices in the big-box stores are insane.
Kurt
Blue Jeans Cable
1 - 3 of 3 Posts
