Status
Not open for further replies.
1 - 4 of 4 Posts
In my area, Bloomington, Insight comunication has served HDTV.
I applied that program and I wanted to use MYHD PC card as HDTV receiver.
But, I could not do that because there is any method to change chnnel number over 750 in MYHD PC card. Do anyone knows how to solve that problem?
Remember, the myHD card can't see QAM signals. That means it won't see any channels transmitted over cable (as is the case for most HDTV) that are sent using QAM.
Do you know for certain that Insight transmits HDTV as 8-VSB over its network?
On most cable networks, you cannot see any HDTV channels (or even digital SD channels) transmitted over cable with the myHD, that is correct.
1 - 4 of 4 Posts
Status
