Now Available: Tech Talk Podcast with Scott Wilkinson, Episode 19 Click here for details.
Originally Posted by Nmlobo /forum/post/0
If it is TIR then it can work. However I don't think there is anything wrong with your set.
When you watch something in 16:9 do you notice that the sides are darker? If you don't see it then, you don't have TIR.
I noticed on my set, before I adjusted the black level, that the center portion of the screen would be lighter (when viewing a black screen in 4:3. Once I adjusted the brightness control and the back light it evened out.
LCDs are not like plasmas. There is nothing to catch up. Image retention is a condition where the pixels fail to unwind.
Originally Posted by miniz /forum/post/0
By bars, so you mean black fillers that are used on a 16:9 TV to fill the gap not used by a 4:3 picture? Or do you have banding or severe image retention? Do you have a Sharp LCD by and chance?
but which bars? I have 3 different bar types listed above. I assume you mean that there are two black bars on the left and right of the screen. If so, there is nothing wrong with your TV. You just need to feed it an HD 16:9 signal. Your problem will be solved.
Sounds like you have image retention. Watch more HD and strech/zoom all of your 4:3 programming to 16:9 for a week or so, then report back and tell us if the problem has gone away.
Originally Posted by user7800 /forum/post/0
I have been doing that all night, should i turn the contrast up or down?
thanks.
Whats TIR? I had my contrast almost maxed![]()
