Status
Not open for further replies.
1 - 5 of 5 Posts
when i plug the s-video cable to my x1 projector the picture became black and white.
what can go wrong?
is it maybe because i don't plug it permanently but only when i use the projector?
thank you
Discussion Starter · #3 ·
the cable has been used for about two month and i returned it to the store.
now i have to buy another cable but i'm concern that it will be damage again.
Be careful when plugging it in; the tips inside are easily bent. Did you check inside both ends and see if any of them are bent on your existing wire? If so, can you straighten it back out?
1 - 5 of 5 Posts
Status
