Status
Not open for further replies.
1 - 10 of 10 Posts
At the recommendation of others, I need a 25ft VGA cable run to my projector through the conduit along with the DVI-HDMI and component cables...
Where can I get a 25ft run? I need male-male to go from computer to projector.
pccables.com!!
cheap...
great construction
i use a 50' cable...works great.
triple coaxial design is required for a proper run greater than 40-50 feet otherwise ghosting will be aparent on lcd screens.
I first had to reurn a cable from newegg since it didn't work at 100 feet. cables-to-go sells grades of cable that work at longer runs.
1 - 10 of 10 Posts
Status
