1 - 14 of 14 Posts
Is there such a thing as a checkerboard to side by side converter?
I can't find a product that will do it.
Banned
That is doomed format and you you try converting to side by side you will end-up with low res images with 3D artifacts.
Mathew Orman
Discussion Starter · #5 ·
Discussion Starter · #6 ·
Originally Posted by walford /forum/post/19544190
Frank is this your xx838? If you have it is supposed to now accept all HDMI 1.4a mamdatory formats directly with the recent update.
Actually, no.
All the 3D in my home is viewed via a windows desktop with the display in checkerboard mode.
This works best for me as I can multitask 2D with 3D without the annoyance of having to switch to full screen to view in 3D.
This device would allow me to do the same thing with my currently useless Panasonic VT20 (no checkerboard support) that I currently do with my two Samsung Un40C7000s and my Mitsubishi 82838.
Discussion Starter · #7 ·
Mathew Orman
The only one which allows mixing 2D and 3D content is doomed! Figures.
I know all about buying into doomed formats. I loved by Beta-ED deck.
Discussion Starter · #11 ·
Originally Posted by almostinsane /forum/post/19545082
Doesn't Stereoscopic player convert one to the other?
It will play any type of 3D stereo video/image and output it in numerous formats.
I set it to output checkerboard format so I can watch 3D videos on my desktop while doing other things.
Since I already have over 8 terabytes of my home made 3D video, I need this ability.
I am thankful that Samsung decided to support it on their 3D televisions.
I demand checkerboard support on any future 3D television I plan on buying in the future!
LG 55" C9 OLED, Yamaha RX-A660, Monoprice 5.1.2 Speakers, WMC HTPC, TiVo Bolt, X1
Originally Posted by Lee Stewart /forum/post/19544581
Did you also have that 25" Sony high performance "cube" TV to go with it?
Yes, it's right next to his Mavica hardware.....
Discussion Starter · #14 ·
1 - 14 of 14 Posts
