Status
Not open for further replies.
1 - 10 of 10 Posts
Hi,
I only have one set of HD component inputs on my RPTV but I have both DTV and Dnet HD receivers. I'd like to get a switcher because I am tired of swapping cables. Anyone have any idea on a switcher that I won't lose any signal with?
Thanks for the help.
Joe
I use a manual Radio Shack Audio/Video Selector PN 15-1952.
It cost under $20. I use it to switch between my DISH 6000 and ExpressVu 6000.
Yes I do have to get up to do it, however I am old enough to remember when you had to always get up to change TV channels.
Hot
LG 55" C9 OLED, Yamaha RX-A660, Monoprice 5.1.2 Speakers, WMC HTPC, TiVo Bolt, X1
Do a search for "Inline".
"Better living thru modern, expensive electronics devices"
tm
I would not recommend the $20 Radio Shack switchbox. I have used this device (and other comparable boxes from Belkin and others) and have had nothing but ghosties, fuzzies and other types of interference.
Back around March and April I posted a series of topics on this very subject (search for my name and you should find them). I finally settled on the Extron SW4 VGAxi and am quite satisfied with the results. It cost $400+, but was worth it.
Scott Gammans
The Scooterplex Cinema 1
I have heard of a RatShack mechanical A/V switcher $20 but you have to physically go and flip the switch between the two. The automatic sensing switcher is $200.
Eram
TV=Sony 53HS10, DVD=Sony DVP-550D, CD=Sony CDP-C335, DSS=Dish PVR 501, Receiver=Marantz S5000, Speakers=JBL M28, JBL PSW-D110, VCR=Panasonic PV-V4620
I have never had a problem with my Radio Shack switch.
Hot
Premium Member
Inline IN3582:
http://www.inlineinc.com/products/matrix/
Around $250, but does the job perfectly. Auto-sensing,
whichever source is turned on is the one fed to the TV.
Only consideration is that its connectors are BNC, so that
you will need RCA-to-BNC from your two sources to the
switch, and BNC-to-RCA for your switch to the TV. You
can get properly built cables (as I did), or buy nine
adapters (I was concerned about signal loss and the
size of the adapters).
The switch actually has 4 connectors for each input/output,
so with normal 3-wire RGsB component video you use the
"Sync" connector for the green wire and leave the "Green"
connector empty.
You might consider logging onto ebay, and search for
video switchers. Extron switchers for RBGS etc frequently
appear. Another, that I obtained, is a Sony switcher
PC-1271 that can be configured with up to eight input
boards. With luck, one can be obtained for about $200.
The PC-1270 or 1271 (later model) will operate as stand
alone switchers unlike Barco which needs to interface
with a Barco projector. Output from the Sony is RGBHS,
composite,S, plus audio. Good luck.
1 - 10 of 10 Posts
Status
