I need an in-wall surge protector for new LCD TV
1412 Views 5 Replies 5 Participants Last post by  sharok
I finally got a house so I am getting started with me A/V setup. I have a Samsung LN52B750 on order and now I need an in-wall surge protector for it.
Can you guys recommend a good unit? I want it to look completely wireless.
1 - 6 of 6 Posts
I like the miw power-pro from Panamax
I was looking on their website and noticed that they do not make a 3-gang model to accommodate other misc. cables, such as, hdmi. What do you use for those wires? How does this unit compare to the Monster power center that had an extra slot for hdmi wires?
Why not get a surge suppressor installed at your panel box too? Depending on the wiring to your house, they're not that difficult or take that long (for an electrician) to install. It'll protect the whole house that way (though having a plug-in surge protector for AV equipment and computers are good).
Look at who makes your panel box.
You can get them at the big box home reno stores (Cutler-Harmer is popular).
This is what Square D offers:
http://www.squared.com/us/products/surge_protection.nsf/unid/69C8B19A6011A07B85256A17005D5766/$file/surgeprotectionFrameset.htm
Monster Cable has a long history of identifying scams and marketing to them. If Monster Cable is your benchmark, then I also have an East River bridge to sell you - also a great deal.
Do you think 2 cm parts inside that little Monster protector will stop what three miles of sky could not stop? Do you think its few hundred joules will absorb a surge of hundreds of thousands of joules? Of course not. Same applies to the in-wall protector. Anything that will protect at the electronics is already inside the electronics.
Your concern is the surge that might overwhelm protection inside those electronics. That typically may happen once every seven years. Nothing stops or absorbs such surges. Effective protection means earthing that energy harmlessly. A surge not inside a building need not hunt for destructive paths to earth via your appliances.
terenz> Why not get a surge suppressor installed at your panel box too?
That solution is most effective even with superior or inferior household wiring. Either that in-wall protector must somehow magically absorb all that energy. Or connect that energy short (ie 'less than 10 feet') to earth so that energy is not even inside the house. So that protection in all appliances is not overwhelmed.
How does a few hundred joules in a protector absorb surges that are hundreds of thousands of joules?
A protector is not protection. View manufacturer spec sheets from Monster Cable. Where does it list each type of surge and protection from that surge? It does not even claim protection? Did you notice that? It does not even claim protection. It contains the same protection circuit also selling in grocery store protectors for $7. Sell that three dollar power strip with fancy paint and some ten cent parts for how much? Does price determine quality? Or do you identify scams by thinking like an engineer? Appreciate what it really provides - a massive profit margin.
Your best solution is a product from companies with honest reputations - General Electric, Square D, Leviton, Intermatic, Keison, Siemens. The Cutler-Hammer 'whole house' protector sells in Lowes for less than $50. But again, what provides protection? Not a protector. A protector is only as effective as its earth ground. Upgrade building earthing (and interior wires to meet and exceed post 1990 National Electrical Code. Better earthing via a 'whole house' protector means superior and effective electronics protection.
A protector is only as effective as its earth ground. Earth ground is the protection. A protector only connects surges short to earth. No earth ground and what does it do with all that surge energy?
Sufficient earthing means a short connection (ie 'less than 10 feet'), no sharp wire bends, no splices, not inside metallic conduit, separated from other non-grounding wires ... How to best earth only one 'whole house' protector and just more reasons why in-wall protectors have no earth ground - does not even claim to provide protection in numeric specs.
Above is only secondary protection. Every protection layer is only defined by its one critical component - earth ground. Also inspect your primary surge protection system:
http://www.tvtower.com/fpl.html
See less See more
I agree with westom. The best protection is at your circuit breaker panel.
I use a device called "EP2050". Here is the website:
www.ep2000.com
Check it out.
1 - 6 of 6 Posts
