Status
Not open for further replies.
1 - 3 of 3 Posts
Premium Member
Hi Guys
I have a customer with an old Zenith work horse and I need the remote. I believe its a 750?
They all worked off the same code so anything from the old series will work.
Alan, you can probably get those codes off a standard run of the mill universal off the shelf (so to speak). They were made by allegro in the pro 851 series, so you could probably aquire an allegro remote and get them that way as well. Also, I'm quite certain all the codes are sitting on remotecentral.com for your easy download into a pronto, then into whatever cheapo learning remote you want...
Ya beat me to it, Mike!
Curt
1 - 3 of 3 Posts
Status
