1 - 7 of 7 Posts
I need your help with the adjustments of gamma and luminance in my set-up. It is my first attempt to get the D65 calibration, I think it was a good start but now I see my gamma going from 1.95 to 2.6. Now I will try to explain.
Set-up:
TV Sony 34XBR960
BD player with Video Essentials DVD
Colorimeter: Spyder3
Software: HFCR and Spyder3tv software
This is the HFCR data file - before calibration: (...inicial.zip)
This is the HFCR data file - after calibration: (...final.zip)
Now this is what I did:
1. Reference: SDTV (NTSC ) D65
2. Display: xzY
3. Read time: 3000 ms
4. Set contrast between 30 to 40 ftL
5. Set RGB gain (30 IRE)
6. Set RGB cut (80 IRE)
8. Set Spyder3tv software
That is all. Now I want to improve it, but before I need know how to adjust the gamma (2170P-4 GAMM?)and luminance(2103-1 CLEV?) in service mode. I know there is a lot I can improve but I am not sure what to do.
Thanks in advance,
Attachment 150583
Sony 34XBR960 inical e final.zip 5.6904296875k . file
Greetings
Gains are high end ... offsets are low end. You have it backwards
regards
There is seperate r, g, and b gamma boosts in the SM. Tyically the XBR960 needs an extra gamma boost in the red to flatten the grayscale, and typically all the colors need 1 click of boost to be around 2.2-2.3 gamma average. I typically get around 40-45 fL of light from a white window. Set your contrast either the conventional way or shoot for between 40 and 45 fL, and then boost each color's gamma by 1. Then boost red gamma another click so it's at 2. Then adjust your black level and grayscale. Use Pro mode to cal.
Discussion Starter · #5 ·
OK. I will do it next sunday. I have another question. How do you know or how do you measure how much gamma (in r, g or b) is need it? Iis possible to measure it in real time? Or I read somewhere that when you set Y between 40-45, you can calculate the brightness (0.63% of Y) and then you can say that you'll have a gamma between of 2.2?. Thanks.
Discussion Starter · #7 ·
Hi,
I did again all the calibration but this time using the 709 DVD. My gamma now goes from 2.3 (10 IRE) to 2.0 (80 IRE) with GAMM set at 1. I noticed that the yellow looks a little more weak, so I got the CIE chart and now I found out that my green primary is offset. Is there something I can do to adjuts it?
Thanks again for your help
1 - 7 of 7 Posts
