1 - 4 of 4 Posts
The 4805 is an old projector, you are going to have trouble finding one, and chances are if you do it will most definitely be used and depending on the bulb, it could be close to its life and then you might have to replace that as well. Do a little shoping around and for around 500.00 to 600.00 you can buy a brand new 720p projector which will be way better then the 4805
1 - 4 of 4 Posts
