1 - 10 of 10 Posts
Discussion Starter #1
I have this Blu-ray player:
http://store.sony.com/streaming-blu...BDPS3200/cat-27-catid-All-Blu-ray-DVD-Players
and this is my Shelf & Music System:
http://store.sony.com/micro-music-s...-27-catid-All-Speaker-Docks-and-Shelf-Systems
The Blu-ray player has one orange Digital out coaxial output and the stereo has only one audio input and is a 3.5mm jack.
My question is there a cable that has 3.5mm jack on one end and digital coaxial on the other end ? and is it going to work well ? I would like to have stereo sound coming through my two speakers.
I don't think so. Looks like the stereo only has analog input. The output on the blu Ray is digital. The only thing I can think that might work is run hdmi to tv and if the tv has analog outputs you can get a stereo rca to 3.5 mm adapter.
The above is your best option. You should be able to mute the TV's speakers if you want the sound to come only from the speakers attached to the stereo. If the TV doesn't have analog audio output then you will need another piece of equipment to convert the digital audio signal to analog.
1 - 10 of 10 Posts
