1 - 4 of 4 Posts
· Premium Member
To use the preset codes, the dish receiver has to be IR and set address/unit code #1. Dish receivers know upto 16 addresses, so one can have more then one receiver in a given room. But only address #1 is preset into universal remotes.
· Registered
Discussion Starter · #3 ·
****Thanks for your help....do I need to set the satelite box's remote control to address #1 or the satelite box itself to address #1?? I'm clueless... Thanks for your patience.
· Premium Member
Both, change just one and they will no longer will communicate with each other.
1 - 4 of 4 Posts
