1 - 3 of 3 Posts
Directv just installed a new 5LNB dish to enable me to receive local Hidef channels... which now renders my Zentith DTV1080 obsolete (unless you tell me I can get it updated to receive the 5 satellites).
The H20 STB that DirecTV is sending me does NOT have a male HD15 RGB output (as does my current Zenith), which is the option on my ROCK PRO.
The ROCK PRO uses a Male HD15 connector is expecting the VGA standard for RGBHV (I can provide the pin specifcs if needed).
My questions are (in order of my preferred solutions
1) Is there any way to update the Zenith DTV1080 to recognize the 5 sattelites?
2) Are there any STB's that would recognize the 5 sattelites and have either of the following
- A male HD15 connector carrying the RGBHV signal OR
- Separate R/G/B/H/V RCA or BNC connectors (I could then get a simple adapter)
3) Can anybody recommend a good quality reasonable priced Component to HD15 RGBHV converter.
Any other suggestions?
Banned
1) No it will only recogonize the 3 and can be used for SD.
2) No - the H20 and HR20 are your only options.
3) Define Reasonable Priced.
Discussion Starter · #3 ·
Thanks for your speedy response!!
I've seen some units for > $300.... I would rather spend much less since to me it's really just a connection issue.... and all of this is simply to add 3 local channels to my current setup
Bottom line is I will need to spend whatever I have to, but would like to keep it to a minimum without compromising picture quality.
Just to be certain that I am clear in what it is I need.... it is a device that will take the YPbPr comonent output from the H20, and convert it to a HD15 Male connector with the following standard VGA pin settings:
Pin1 Red
Pin 2 Green
Pin 3 Blue
Pin 6 Red Ground
Pin 7 Green Ground
Pin 8 Blue Ground
Pin 13 H sync
Pin 14 V synv
1 - 3 of 3 Posts
