These Focal Chorus towers are a great deal.
Now it's your turn. How do you like them?Quote:
Originally Posted by Leroy Bad /t/1518780/i-need-speaker-recommendations-for-a-small-room#post_24500447
As an Update: I wound up with a pair of Focal Chorus 807 W Prestige.
Thank you all for your help and suggestion
Originally Posted by buzzy_ /t/1518780/i-need-speaker-recommendations-for-a-small-room#post_24500476
Originally Posted by afrogt /t/1518780/i-need-speaker-recommendations-for-a-small-room#post_24500827
surprised the Focal's are louder. Bic claims a sensitivity of 96db for the FH65B while Focal claims a sensitivity of 92db for the 807.
The Bic should be louder at the same volume setting but apparently that's not true.
Originally Posted by Leroy Bad /t/1518780/i-need-speaker-recommendations-for-a-small-room#post_24500934
It's difficult for me to put into words, though the volume is the same , it's like I'm hearing it from a different perspective. Instead of standing in the doorway listening to the musicians, I've been invited to the third row seat from the front. The band doesn't play louder, I'm just closer to the stage which is much larger.
Originally Posted by Leroy Bad /t/1518780/i-need-speaker-recommendations-for-a-small-room#post_24500560
I've only had them for about an hour, shuffling through various tracks. Rights from the beginning they don't go as deep in bass as my FH-65B, but the soundstage is bigger and has more depth. They are louder than the my previous speakers too.
Originally Posted by cel4145 /t/1518780/i-need-speaker-recommendations-for-a-small-room#post_24502051
Nice! Once you get your new subwoofer, that will help to fill in the bottom end. Check out the AVS subwoofer forum to get help on subs.![]()
Originally Posted by Leroy Bad /t/1518780/i-need-speaker-recommendations-for-a-small-room#post_24502189
Actually I already own a subwoofer, which these new speakers are presenting a challenge with. With my previous speakers my Dayton Sub-1200 sounded big and loud, so I was careful with the crossover and gains. But with the Focals the sub is barely audible. I have moved the cross over to 70 and the gain is almost at max, and it sounds very weak. I wonder if the Focal Speakers are taking too much power from my receiver, leaving less for the sub. Even worse since the Focals are louder I have to turn the volume down from 40 to 30 on the reciever, which is too low for the sub's Auto Switching to kick in. Has anyone else experienced this?
Originally Posted by Transmaniacon /t/1518780/i-need-speaker-recommendations-for-a-small-room#post_24502209
Make sure your speakers are set to "small" in the receiver. If set to large, they will be getting the full-range signal making your crossover less effective.
Originally Posted by Leroy Bad /t/1518780/i-need-speaker-recommendations-for-a-small-room#post_24502232
I don't have that type of receiver. It's a Onkyo TX-8050 which is stereo only, the out put is full range and subwoofer pre out cross over is 100hz.
