I use SPDIF out only - would an X-Fi xtreme Music improve my audio?
3367 Views 45 Replies 19 Participants Last post by  mattburk
Subject says it all. Would it improve my sound?
I use my HTPC for playing video/DVDs and listening to MP3s, with Martin Logan electrostat speakers.
Status
Not open for further replies.
1 - 20 of 46 Posts
no. for spdif I would avoid Creative Products altogether.
I am personally done screwing around with the Chaintech / ASIO4ALL situation as well. The m-audio and Audiotrak prodigy products just under a hundred bucks do a great job with native bit perfect output using ASIO/Kernel Streaming. These cards will generally work out of the box with no special tweaking and will automatically output the appropriate sampling frequency for DTS/AC3/PCM without introducing any crappy upsampling which many of the Creative products are known to have problems with.
The X-fi, even if it does proper ASIO bit perfect output via spdif is seriously overkill in cost and won't net any benefit above the sub $100 Audiotrak and m-audio stuff.
Blazar, You seem to know a thing or two about audio. Have you tried any card that has DDLive? As I read this is supposed to expand MP3 and other stereo sources to DD5.1. Maybe this is a reason to upgrade even if you only use SPDIF.
DDL cards only encode DD on analog 5.1 sources such as WMA5.1. 2 channel audio is NOT converted to DD5.1. DPLII is what you'll need for 2 channel to 5.1.
You don't say what you're using now to output via SPDIF but I got a significant improvement recently by installing an MAudio Audiophile 24/96. I had been using my Asus P5GD2 mobo's SPDIF output both for DVDs/music and for gaming. It has DDLive and it's great for surround effects in games like Doom3, FEAR and HalfLife2. Compared to the SPDIF output of the 24/96 however it's lacking for movies and music. I believe it's because the mobo output resamples 44.1khz audio to 48khz whereas the MAudio passes it untouched at 44.1.
peace,
Mark H
Correct me if I am wrong, but I thought most AC-3 (DD) movie sound tracks are sampled at 48khz.
Even with resampling of CD music at 44.1Khz, the compression artifacts of MP3 is going to be FAR FAR greater than any effects caused by resampling to 48khz.
How many channels is your listening setup? Also, how are you encoding your mp3s? Like someone hinted here, I would use a lossless encoding format, like flac.
You might be interested in this article (htpc -> squeezebox music streamer -> benchmark dac -> amps -> speakers)
http://www.silentpcreview.com/article287-page6.html
- Steve O.
See less See more
peace,
Mark H
That's the part that is confusing, the degradation in the resulting upsampled signal will depend on the capability of the hardware ADC/DACs and also the sampling method used. I will challenge anyone who told me they can hear a subtle difference between a signal sampled at 44.1KHz and 48KHz using a good ADC/DAC.
The converters on the Creative card while not the best available but are not that bad to create such significant difference in sound you guys keep pointed out.
See less See more
no
Hi, Bryan!
I've recently been doing some testing with the X-Fi Platinum (the same board, but with an additional break-out box), and the results are fascinating. First, it does have extremely low THD via PCM S/PDIF - far better than just about any other card that I've seen. In addition, its frequency response is exceptional compared to most other sound cards - dead flat.
However, while I'm still very much in the middle of investigating what's going on, the current drivers apparently have a problem, because when complex waveshapes are injected into it, the resulting PCM outputs, as well as the analog outputs, show strong distortion of the incoming waveforms. While it's too early to know the precise cause, the distortion is unquestionable. If you're curious about my quantitative testing techniques, they're documented in the XPlosion thread here . Once I've collected more information, I'll post the complete results. For now, though, I'd definitely hold off on ordering this card.
FYI!
MarkF
See less See more
Hi, Bryan!
What the heck - I'll post a few screen shots just to whet your appetite. Here's a plot of the Total Harmonic Distortion of the X-Fi's PCM outputs at 96 KHz:
http://www.talix.com/RX/THD96-SBXDAA.PNG
Zowie! That's a bloody amazing result. Now here is its frequency response curve:
http://www.talix.com/RX/FREQ-SBXDSD.PNG
If those don't impress you, please check out the results of my testing with other cards in the thread I linked to! Next, I always test with a special data pattern that looks like a perfect circle on an X-Y oscilloscope. The X-Fi shows off its processing prowess with the best internal loopback pattern that I've ever seen:
http://www.talix.com/RX/EFQXY-SBXDSD.PNG
However, once we look at what happens with its dynamic response over the PCM S/PDIF outputs, reading the receiver's analog response in place of the loopback input, things look quite poor. Compare this image to the other cards that I've tested, and this isn't looking good:
http://www.talix.com/RX/EFQXY-SBXDDD.PNG
While I won't post it just yet (until I know more), the analog outputs are far worse. Given its spectacular digital front-end, something's just not right with the outputs. Given the left/right imbalance we see, it's likely that the drivers aren't initializing the card correctly, or that some of the various "add-on" processing can't be disabled fully, even though the UI claims so.
As I learn more, I'll post it here.
Cheers!
MarkF
See less See more
Mark,
I appreciate your posts because you do the all the work and we just sit back and reap the rewards.
Hi Mark, I agree with Gushy absolutely. Off to read your review now...
Speaking of the MAudio 96/24, I have an MAudio Audiophile USB that I originally bought to use a laptop as a music player. Is that card as good as the 96/24?
Hi, Gang!
Thanks a bunch, guys! :) I must admit that I've always been a little frustrated with "audiophile" opinions that are filled with qualitative terms like "warmth", "character", "clarity", etc (especially when they're referring to stuff like speaker wire!). After developing the EFQPSK receiver, I feel like I've finally found something that can take all those opinions and turn it into repeatable, quantifiable hard data, which I'm personally a lot more comfortable with. The coolest thing is that the EFQPSK data pattern allows us to examine the critically-important dynamic response in ways that THD & frequency response don't even see!
Who knows, once I've properly characterized what's going on, I may well file this information with Creative, so that they themselves will have a better, more "scientific" method of characterizing dynamic response, too! ;)
Have Fun!
MarkF
Hi, Bryan!
Generally speaking, the M-Audio cards are indeed well-designed, and my tests thus far have always been favorable (other than their limited drivers). However, I'm afraid that I've never tested the Audiophile USB. Can anyone else shed any light on this peripheral?
Sorry!
MarkF
"Quote:
no "
not so fast.... it depends on what you are using as a sound card NOW... if, for instance, you have a varient of the Audigy series card, and if you play PCM audio such as ripped CD's, then YES, the vastly improved SRC on the X-FI will dramatically improve your audio !!
:cool:
See less See more
Hi Jim,
I'm using the onboard audio of my MSI K8N motherboard, which is an nForce4 motherboard with the Realtek AC97 codec.
I assume my setup is not outputting native 44.1Khz.
... and you WOULD see/here a difference....
:cool:
:cool:
Hi Jim,
Not too long ago you have a thread here regarding the X-Fi elite pro. I remember you mentioned how the THD was low when resampling to 96KHz. I'm using "J River media player" for playback (.ape, flac, 320Kbps mp3). J. River output mode is set to 24bit and asio with 96KHz re-sampling.
Now, my understanding is the player perform the resampling via software and passes the resampled signal to the card, how do I get the re-sampling to be performed by the X-Fi?
Creative keeps mentioning that the card can resample to up to 192KHz, however, I seem to be able to resample to up to 96KHz only, am I missing anything?
See less See more
1 - 20 of 46 Posts
Status
