Originally posted by HAN
Joe: (I run an ICBM for full time bass management between my Denon 3802 and a Carver 5 channel amp.)
Does the A-1 have a complete 5.1 set of pre-amp outs and power amp ins? If so, then you can try either setup you describe. And in the end, that is exactly what I think you should do. |
Han,
It's an oddball arrangement regarding pre-amp outs and power ins.
The DSP-A1 has pre-in/outs for the 2 front speakers and
pre-in/outs for the Center. There is a jumper between these 3 sets and I am feeding the pre-out on the Front to a Stereo Parasound Amp connected to the Fronts.
Using the internal amp for the Center and Rears.
The Rear's are a Normally Closed RCA jack designed to allow connection of an external amp and the SUB is line level out.
Doesn't look like I can put the ICBM between ALL the ins/outs on the Yamaha because if I connect an RCA jack to the Rear, I would need another stereo power amp due to the NC connection.
Make sense?
Only had time today to mess with the DVD-A going to the A1's 6 analogue inputs.
This sure gets a bit complicated and after reading the A1's manual CAREFULLY I realized that what I posted earlier was not completely correct.
When using the 6 analogue inputs, it bypasses the DAC and the DSP chip (obviously) but bass management is available on the Yammy.
Front/Center/Rear can be set to small or large individually and the cut frequency is fixed at 90 Hz for each if set to small.
I am starting to think I made a mistake buying this.
I assumed from all the comments about DVD-A players not having Bass management that I would need the ICBM and that the Yamaha would not have bass management when using the Analogue inputs.
It dawned on me that I NEVER use Bass management from my DVD player (DD,DTS) since I can do it via the Yamaha. I have the Rears and Fronts at Large and the Center speaker to Small.
Here is the +/- 3db bass spec on the speakers
NHT 2.9 Front - 26 Hz
Audio Center 1 - 75 Hz
NHT 2.5i Rear - 26 Hz
Velodyne FSR-12 sub (12", active servo)- 20 Hz
I found the best sound was settting the ICBM to 40 Front,100 Center and 40 Rear. I could not tell any difference when setting Front and Rear to bypass.
Anything higher sent TOO much bass the Sub and the sound was boomy.
If you look carefully at my settings, you will see that I basically have the ICBM set the same way as my Yamaha's own Large and Small settings. The only difference is 100 Hz instead of 90 Hz for the Center.
Perhaps if I had a disk with front or rear bass below 40 Hz, I could tell the difference. I only had time to experiment with Brain Salad Surgery.
BTW, I re-calibrated all the speakers at the Large setting on the Yamaha to 70 DB with VE before I hooked up the ICBM. The DVD player was set to all Large also.
I am going to experiment some more tomorrow with other DVD-A and DTS CD's but I have a feeling I am sending this back.
Ideas? Or am I missing something here?
Oh yeah, thanks in advance for reading through this long post
Joe
