It will work with the majority of compression fittings out there.
Originally Posted by Whidbey /forum/post/12817611
I recently purchased a Radio Shack coax stripping tool and an IDEAL compression connector tool ( http://www.idealindustries.com/prodD...?prodId=30-633 ). Using the IDEAL connectors, they have worked out very well for me.
My question is: Is the compression tool only going to work with the IDEAL brand coax connectors? I'd like a bit more freedom of choice when buying compression connectors, if possible.
Originally Posted by Whidbey /forum/post/12823363
Thanks for the replies. After posting, I realized I could have just read the PDF on the website, which is the front label that came with the tool, which states:
Assembles the following 59 and 6 series Fconnectors
- IDEAL PPC CMP and EX/XL
- PPC EX/XL
- Telewire Digicon-S
- Gilbert Ultraseal
- Thomas & Betts Snap-N-Seal"
