Originally posted by rm -rf *.*
You said "mailserver/webserver" - is the this potential DVArchive server located in an "exposed" area or a DMZ? Or is it located on your internal net and your firewall is forwarding the appropriate traffic to (and back - from) this system's httpd & smtpd services? Or ________ (insert any one of thousands of other possibilities in space provided)? |
The SuSE Box is behind a firewall on my internal network with all appropriate ports being forwarded to it. It is kind of fun to pull up the firewall summary and see all the ports that the machine is hosting.
If this Linux server is handling a "medium" (or greater) level of http & smtp traffic - I'd start to wonder if the load on these services might start to interfere with DVArchive services/requests - specifically, the streaming server & performance with MQ & HQ shows, streamed both individually and even more so if DVA is streaming shows to multiple RTV's. |
I'd say the traffic volume is rather low. The box's main function is to act as my personal e-mail account. I have also set up some other mail accounts for family members who use them sparingly. The http traffic is just to my family webpage feature photos of kids, resumes, etc. Oh, and of course the interface for Squirrelmail webmail.
IMHO - If our "places were swapped" right now, I'd be giving serious consideration to just going and getting an under-$150 refurbished PIII system and turning that into dedicated 24/7 DVArchive server. IMHO - this simplifies things considerably - the Winblows compatibility requirement for the file system that will be used on the 120Gb drive that will hold the DVArchive Guide would no longer be an issue, as you can just install DVArchive on the windows system also and then use it to copy a show from the Linux DVArchive server to the the windows system (itself).
Just a random thought.... |
I paid $150 for this machine at Fry's (I couldn't pass it up). It is an AMD Duron 1800 with 128 MB of RAM (definitely needs more before I add in the DVArchive bit). I'd prefer not to have to administer yet another computer for the sole purpose of Archiving/Scheduling with DVArchive. I intend to uprade it to at least 512 MB of RAM then I will give it a go. I'll report back on my success/failure once I have everything configured.
As for filesystem, any other votes for reiserfs? This seems to be the default filesystem for SuSE. Does it have any file-size limitation similar to FAT32?
Thanks all for the feedback.
