ideal height for plasma
685 Views 4 Replies 4 Participants Last post by  igreg
I am gathering info and "getting ready" to purchase an ED plasma - most likely, the Pan 7UY.
There's lotsa new stuff to learn, so if there's a newbie FAQ that covers this, point me to it.
I'm thinking about building a shelf system to support the audio/video components underneath and perhaps even act as "the stand" - placing 2 metal shafts of the correct diameter and length at the correct distance, creating a larger "stand", if you will.
I'm wondering about the preferred height for the screen. Is it the (horizontal) center of the screen at (seated) eye height? Seeing some of the plasma tables at 24" height, using half of 24" (height of 42" plasma), that's a center of 36", pretty close to eye height when seated. This can vary, of course, based on the height of the couch and the person, but I want to verify that this is the goal.
I'm also curious if anyone has built their own stand and what diameter/length shaft is expected. I think it would look cleaner, perhaps even be adjustable in height (depends on the implementation) and be more stable - secured to top surface that is wider and longer than the Pan stand.
Status
Not open for further replies.
1 - 5 of 5 Posts
Here's a method for wall mounts. If you are stand mounting the plasma, I'm sure you can adjust.
Figure out where you want to sit and place your comfy chair there. Folks who intend to do a lot of HDTV or high quality DVD watching will likely want to sit closer than standard-def TV folks so as to get that "immersive" experience which is possible when you don't have to worry about the noise and other issues in standard-def TV. In my case, my eyes are almost exactly 9 feet from the front surface center of my 50" plasma when my head's in a comfy viewing position. I was targeting a range of 7 to 10 feet for watching high quality stuff so this works well even if I sit up or lean forward.
Having decided where you want to sit, get a sharp-focused light such as a laser pointer, sit in the comfy chair with your head lolled back the way you really like it, and line up the pointer along side you head along your line of sight. Pick a spot on the wall you think is precisely in the middle of your most relaxed line of vision and turn on the pointer and see how close it comes to hitting that spot. Usually your most relaxed line of vision will be a little LOWER than what the pointer would indicate. Something in between is probably a good target for the ideal center height of the plasma based on the idea that your eyes will naturally come up a bit when you are watching something intently instead of just letting yourself relax completely. There's no such thing as a "standard" height here since everyone's seating is different.
Measure the outside dimensions of the plasma (including the frame and any attached speakers) from that candidate center point to make sure you aren't hitting any obstructions. Keep in mind that the studs in your wall may be placed such that you need to shift the display left or right a few inches from your ideal location depending on the flexibility in your wall mounting system. However, you will likely be able to get exactly the height you want.
Mark all 4 outside dimensions and also the actually viewing screen dimensions on the wall with masking tape and double check from your viewing location. What you are looking for now is whether there are any problems seeing the edges of the display. Keep in mind that the front surface of the display is going to be several inches out from the wall -- 5 inches is fairly typical for a fixed mount, more for a tilting or articulated mount. If you have a thick mounting system such as an articulated arm, and if you are mounting the plasma high up, you may even want to try to correct for parallax error in your measurment (i.e., your line of sight to the plasma actually terminates at the screen, not at the wall behind it, and THE SCREEN center is what you are trying to determine.
Adjust the height as necessary to account for obstructions such as any floor-stand mounted center speaker, your toes when you stretch out, or things hanging from the ceiling. Make sure you have allowed for ventilation clearance on all 4 sides. You should also consider what's behind you that can't be screened off, since the glass in plasmas is pretty reflective. A higher screen will reflect things on the ceiling such as inset lighting. A lower screen will reflect things more directly behind you, perhaps windows, mirrors or glass fronted cabinets. As for windows behind you, it's not just daylight you want to be concerned with. Plasmas put out enough light that you may see a reflection of the plasma's own image bouncing back off the window to the plasma and out to you again.
If you intend for multiple rows of viewers to be seated, and your floor isn't raked like a theater, then you'll need to place the display high enough that the folks in back don't have to look through your head (I'm presuming you'll take the good seats in front).
There are all sorts of issues that may cause you to place the plasma at other than the ideal height. A low ceilinged room, placement over a fireplace, or placing the plasma out of reach of grubby hands of toddlers for example. It's a real nuisance to take down and remount a plasma on the wall so if you are doing a wall mount, it's good advice to make a mock up such as the masking tape idea (a cardboard box of the right size taped to the wall would be better) and leave it up for a while to see if any problems occur to you.
Also, since the plasma is really not flush with the wall like a mirror but sticks out more like a sculpture, take care if you are placing it where people might walk by and catch the edge, perhaps with something they are carrying. Locating the plasma close to a corner that people will walk around is probably not wise for example.
One final thought: If you watch TV with multi-focal glasses or bifocals, make sure you place the display high enough that you are not forcing yourself to look through the reading portion of the lenses when your head is comfortably resting.
--Bob
See less See more
--Bob
Superb response Bob! Me thinks, however, you have dated yourself.:D ;)
Gooddoc Out
Thanks. I was looking for a "standard measurement" or "YOU determine the standard" answer, and I got it.
I am one with the height of the display.. ommm....
I have read comments that for a wall mount the best height is where top of plasma is at six feet, and for a table stand the ideal height for a large plasma would be where your eye level is 1/3 of the way up the height of the plasma (as opposed to 1/2 of the way up). Your opinion on these recommendations?
Trying to decide myself what height of stand to purchase for a 50" plasma, with the standard stand heights being either 28", 24" 21" or 18". At this point, I have narrowed the choice to either a 24" or 21" stand. What height have others used or recommend for the 50" Panasonic UY plasmas? I am also looking for a stand that preferably has three shelfs in addition to the top shelf so that I can store four components and a center channel speaker; however, I find it unusual that most stands only have two shelves which would require you to stack components.
When taking your measurements, remember to allow 2.7 inches of height for the Pansonic table top stand.
Recommendations? Thanks.
1 - 5 of 5 Posts
Status
