Anyone familiar with the Ideal-Lume Pro? It would be nice to have an accurate reference to verify meter performance once in a while.
http://www.goestores.com/catalog.asp...37008&detail=1
Now Available: Tech Talk Podcast with Scott Wilkinson, Episode 19 Click here for details.
Originally Posted by GeorgeAB /forum/post/15484422
Best regards and beautiful pictures,
G. Alan Brown, President
CinemaQuest, Inc.
A Lion AV Consultants Affiliate
"Advancing the art and science of electronic imaging"
I have used it as a stable reference for checking meters in my lab over the years. My methodology is as follows: set up in a light controlled environment with no colored surfaces nearby, 15 minute warm up to stabilize the phosphors, then measure the illumination bouncing off of a true neutral gray reference (Munsell notation or photo gray card).
Testing has been performed with several samples of several types of meters, and several samples of the light, by several technicians and companies, over the last nine years. Very consistent results have been noted, all within +/- 0.005 x/y from CIE D65, or better.
There are others on the forum who have used this product and may yet comment. I know the folks at SpectraCal use the lamp as a reference. Our product includes color correction film to improve the white point accuracy of the lamp. There are PDF downloads on our site from our lab and GretagMacbeth's that document the spectral performance of several samples.
CinemaQuest, Inc.
Will it be possible tomeasure luminance directly, or is illuminace the "only way"?
any recommendations on a gray reference? Munsell ?
Do you seriously work for CinemaQuest, Inc.? If so, I just want to inform you:
1) Your website is fugly.
2) Your double-sided sticky velcro tape is worthless.
3) The filter inside the Ideal-Lume Standard (IL-01) is absolutely ridiculous. It gives you the option to shine your light up, or down, and that's it.
You guys have NO competition whatsoever in backlighting, but that doesn't give you an excuse to slack.
Originally Posted by anbjornk /forum/post/15488159
Thank you, George.
I'm pretty sure I'll invest in a Ideal-Lume Pro lamp, so that I can check for possible meter drift once in a while.
Will it be possible tomeasure luminance directly, or is illuminace the "only way" ? If so, any recommendations on a gray reference? Munsell ?
Originally Posted by GeorgeAB /forum/post/15496572
You bought a product I manufacture. Sending someone money doesn't entitle you to treat them like your ***** or your whore in public. You are rude, narcissistic, obnoxious, and still off topic.
You guys have NO competition whatsoever in backlighting, but that doesn't give you an excuse to slack. I would appreciate it if you made your products better, and at least take my three complaints into consideration. I have gotten two of my closest home theater enthusiasts to also buy Ideal-Lume Standards, and they both agree with all three points I made.
Ideal-Lume Standard (IL-01) Owner,
moshock
Originally Posted by Ranger481VS /forum/post/15668122
While points 2 and 3 may be vaild, your 1st comment is subjective and unecessary.
Originally Posted by bolistik /forum/post/15756410
I have a 36" LCD TV which is mounted on the wall. The spacing bettern the back of the TV at the wall is about 5" apart.
Which is recomended way to mount the Standard Ideal-Lume on my tv?
a) lower bottom on the back of the tv, bulb facing upwards
or
b) in the middle of the backside LCD tv, bulb pointing at the wall.
