Status
Not open for further replies.
1 - 2 of 2 Posts
Given no ambient light control during the day which screen would you use for a Sony HS-10-- a .8 gain, gray Hi Contrast Da-Mat screen 52" x 92" or a 1.0 gain white Da-Mat screen. In general, what do you guys think of
DA-LITE screens. I can buy either of these screens for less than $199.
Thannks,
Andrew
to reject ambient light you should consider the Da-Lite Hi-Power with at 2.8 gain. do a search on the words Hi-Power and you will get a zillion hits with all sorts of opinion but the bottom line is the retro-reflective properties of this screen and it's ability to reject ambient light is precisely why I chose it,... there are a number of limitations to this screen not the least of which are a narrow viewing cone but your research will pay off with all that information.
1 - 2 of 2 Posts
Status
