Ok, I made a screen frame and finally stretched my blackout fabric on the frame and stuck the thing on the wall temporarily. Was worried about creases from bracing but you can't see it. I'm happy with my screen and need to hang it up. Its about 47 x 84 inches. I'm projecting a smaller picture on the screen than that, probably only 80" wide maximum.
My wall is crappy paneling and I'm not sure how to fasten it to the wall so its as flat as possible. Any suggestions?
thanx
thanx
