That's a big room to fill with that sub, you may just want to try the sub next to the couch and just do it nearfield for the best performance.
Oh yeah, calibrate your sub with an SPL meter.
Originally Posted by rynberg Either to the right of the couch or, if that is localizable, to the right of the right speaker. This will partially corner load the sub from those stub walls. To the right of the couch will put you in the nearfield, making it easier to hit the required levels in that big space. |
Originally Posted by Deathwish238 Put the sub in the main listening position. Play a test tone, walk around your room, and see where it's the loudest. Place the sub there. |
Originally Posted by Deathwish238 In the OP's setup what made you decide to think it's best next to the couch? I understand fully what you're saying...however I'm yet to see a better method to figure out where a sub can go. I doubt every setup will be best with the sub next to the couch. |
Originally Posted by Avatar74 Per Dolby Laboratories' recommendations, position the sub between the Center channel and the front right or left speaker. See my setup below for reference: LFE channel output lacks phase characteristics and therefore disperses throughout the room... this dispersion is most uninhibited and mitigating of false colorations from room acoustics by firing the sound into the open space between the viewer and the screen. |
Originally Posted by rynberg I couldn't disagree more. You are talking about a situation where the entire listening room is constructed and setup according to Dolby's recommendations. This is certainly not the case here, nor is it in 99% of home situations. Besides, not everyone has a shielded sub and/or digital display.... |
Originally Posted by Avatar74 Are you just disagreeing to be difficult, or do you actually have a cogent basis for your disagreement that can be meaningfully quantified? |
