In the Local_Guide directory you'll see 3 new files. 'samefilename RTV.mpg / .ndx / .evt'
so if the file name of the show was 'foobar', you'll have a show called 'foobar RTV.mpg' plus the associated evt and ndx files
You need to export the file in DVArchive (export foobar) and then rename the exported XML file to 'foobar RTV.xml' then copy that, and the 3 other files, into a temp directory. When you import all the show information will be valid.
John
John
