Originally posted by metropole On my Yamaha receiver I can select 6 or 8 Ohms. My speakers are: 8 Ohm nominal / minimum impdedance 4 Ohm. What should be my receiver setting? |
Originally posted by metropole So, with other words there would be no harm in my setup to use the 6 Ohm setting. The result would be a cooler running receiver with possibly some audio detail loss? Is there any speaker type (Ohm) that would be harmed? |
Originally posted by M Code but a good measure is to put your hand on its top after pushing it the amplifier to your expected volume levels.. If hot, then then first I would adjust the volume down. Or try the 4/6 Ohm position, .. |
