Well, we carefully picked different filter widths, but you can't actually choose the "strength" of the filter atm. I've already talked with Javs about this earlier: Choosing the strength might make sense. E.g. you could use "are you nuts" but with only 20% strength or so. The tricky part is that I don't really want to offer multiple different options for Highlight Recovery. But maybe we can combine it. E.g. increasing not only the filter width, but also the strength at the same time?
It would be nice if we could review this again, after the custom curves and desat topics of course.
I am sure there is room for improvements here too. Maybe just lowering the width would do, or using a lower strength, but this will need to be tested properly, in due time.
The "very low" preset would be at 2,625 width to follow the logical sequence, if you want to add it in the meantime.
It could already improve the experience for some users, without hurting anything or requesting any development time, so why not? 🤷♂️
Considering all the pros and cons of all the options, I stopped with this for now as an "all purpose" or "set it and leave it" configuration:
Thanks to the "don't add peak nits" option, I was able to lower the shadow recovery and the sky detection strengths a bit
Edit: Obviously, you enter your own DPL in the right place.
I am taking a little break now from testing, spending more time to actually watch new HDR movies, patiently waiting for the next build
PS: if you have any questions about my configuration, feel free to send me a PM. I will not answer here, unless it is on topic (about desat options).
